11" clutch
11" clutch
Hedgehog
Always Off-Roading Jeeper
Tucson/Marana Arizona
Are any of you running an 11" clutch in your CJ's? The flywheel I have is drilled for both 10.5" and 11" pressure plates. Rob at Willys Works ran one in a hot rod CJ he once had. It's been a bit of a hunt but low and behold parts are available to build one up. Why parts you might ask. It's all in the parts jumble that was a CJ5 and complete parts kits are impossible to find. Why? Well the pressure plate is for an AMC truck or Wagoneer. The friction plate is for a Ford, but not all Fords, it's 11" dia, with a 10 spline center with a 1 1/6" diameter shaft. Gotta be careful here, some swear that the shaft diameter is 1 1/8". The through out bearing is of the Ford square pinned variety. So, the question, "Is an 11" clutch worth all the trouble as compared to the common 10.5" clutch?
My flywheel was drilled for only one size of p'plate.
I guess quite a few of the AMC flywheels are drilled for both 10.5" and 11" pressure plates. Way back when you and I could still hear the Buick (231 V6) flywheel would take the heavy duty pressure plate but it wouldn't fit under the bell housing that I had.
Hedge, with the size of engine that you have and adding that T-18 , it might not be a bad plan to go with the big clutch. It would also help if you ever put on a set of sand tires and head into the dunes.
:agree:
