Build Thread 1959 CJ5 "One Piece at a Time..."
oldjeeplady
Full Time Jeeper
Lifetime Supporter
Eagle, WI
1979 CJ7 V8 304 T18 w/gran low D20 w/TeraLowD30 D44,
1959 CJ5 Rebuild 74 Buick 231V6 oddfire T14 D20 D30 D44 frame boxed roller engine ready,
1967 CJ5 V6 225 T86aa D18 D27 D44 runs needs work,
1954 CJ3B F4-134 T90A D18 D25 D44 Half Cab needs tub,
One Piece at a Time - Based on the Johnny Cash song written by Wayne Kemp. No we didn't steal it but the rest of the song fits!!
This build is based on a 1959 CJ5 that we bought a few years ago. At least that’s what the Wisconsin title, nameplate and numbers stamped on the frame all match to. But the rest of this CJ is a mix of different parts from different year Jeeps and some that are not even Jeep at all. So we called it the rat jeep.
The engine is a 75-76 Dauntless Buick 225 V6 231 odd fire based on the casting numbers I found. The Transmission a T86aa and Transfer Case a Dana 20 . Here’s where things get strange. The axles are Dana 27 front and Dana 30 rear. Have you ever seen a Dana 30 rear? They are really small even compared to the Dana 44 in our ’54 CJ3b . After a little research, I believe the donor vehicle was a ’67 C101 Commando. That axle setup was only used for one year as the Dana 30 rear was a very weak rear axle. The person that built this mess put the wrong length rear springs in so the rear wheels did not line up in the wheel wells :eek: and actually rubbed on the tub. These springs don’t measure to anything “CJ” or “jeep” that I have found and really caused a problem. The V6 conversion was done totally wrong – mounts in the wrong places – chicken tracked welding and well you get the idea. The engine actually sat at an angle, and because of the wrong rear springs the rear driveshaft was compressed and tight jammed up between the Transfer Case and the rear differential. No free play in the drive shaft at all. :eek: The engine actually ran pretty well, and things weren’t too bad as long as you were not moving. This CJ wouldn’t steer or brake correctly and kind of hopped around the yard. It also came with a full Kelly steel top that is in good shape. It has an aftermarket tub with some really strange looking front fenders all pretty much rust free. So for $600 I thought it was a great deal! ;) It was originally bought as a parts jeep for our ’67 CJ5 – but hey this one has potential on its own. :D
Now the original plan for this CJ was to make it more 1959ish. A while back we found a ’60 roller frame in better shape that our ’59, complete with D25 front, Dana 44 rear (offset) 5.38 ratios 19 spline, and 9 inch brakes. When I bought the ‘54 CJ3b the owner threw in another (running) F-134 complete with T-90 and Dana 18. So we would be all set for a ‘59ish CJ, but I wanted at least 10 inch brakes, and we decided to use this CJ for the 2014 Colorado trip so our plans have changed.
This is basically our plan:
1. Use the better frame, repair, box where needed, blast, prep and paint.
2. Use the Buick 231 V6 T86aa Dana 20 combo from the rat jeep.
3. Obtain Dana axles that would work for our set up and allow for a rear locker. So I think I need a 30 spline and at least 10 inch brakes and also want the option of putting disc up front. The thinking is something like a Dana 27 front and Dana 44 rear out of a mid 70’s CJ should work, but this is still under investigation.
4. Install a 2 or 2.5 in lift with new springs, shocks and everything.
5. We have 4 wheels from the 3B set up for 31’s so we will clean these, find a spare and buy 5 new tires.
6. I’m not sure right now on the steering, as that depends on the axles somewhat, but we want the option to install power steering (at some point). :drool: The engine already has the drive pulley. Onboard air would be great too.:drool::drool:
7. The tub, hood and front fenders from the rat jeep are strange – but steel and good shape, so we will use these. We might cut away some of the front fenders or adding some fender flares might make it look better. It’s functional now – it just looks weird.
8. This CJ will be totally rewired and a fuse box installed. I have read a lot about CJ wiring using the frame for return current and the problems this can cause, especially in starting circuits, so each circuit will have a ground (DC return) wire run (and of course the frame will be grounded).
9. We need to find comfortable high backed seats we can install drivers and passenger side. We have none at this time. Suggestions on what would work out of other vehicles would be appreciated. We can make seat brackets as needed (well my husband can).
10. I want to install a roll cage – I don’t want to need it, but I want to have it. I think I have seen kits or plans that a soft top will fit over. (my husband says he needs a tubing notch tool for this… there are more tool purchases in our future…:rolleyes:)
11. I will probably just buy a soft top. I could rob the soft top and door hardware from the ’67 CJ5 and just recover it or fabricate one from scratch, but I don’t think there will be time.
12. I’d like a winch, but don’t know if that will happen right now.
This is obviously my first build (thread). I promise there will be mistakes – wrong terminology and the like. I’ll add some pics next. And everyone can laugh at where we are :o and how far we have to go…. :rolleyes:
But I believe…. and I hope you will too!...:chug:
Oh my , we need pics badly. It sounds like an aggressive project.
Yes, 67-69 Jeepster
:agree:
Great to see your thread started! Remember, TapaTalk is your friend on these build threads that have a lot of images. I don't know what your timeline is, but if your taking this one to Colorado you should shoot for having it done by 7/15 or so, because with that kinda work you do not want SW Colorado to be your testing ground. You can use those last 4-5 weeks or so for some thorough testing and cosmetics.
Believe me - I am not telling you what to do or not do (I rarely know myself), but the only leg up I have in this trip is that I've been there before and I know that the most important thing you need in the Ouray area is good brakes and reliability. It's more important than power, lockers, tires, suspension, tops, paint, heat, air, lights, etc.
We need pictures please:)
There are some earlier pics of this CJ in my gallery but I need to ref them here.
I have a bunch of recent pics I need to resize and upload to photobucket.
I have a smartphone and I bought tapatalk a while back, and then they made that version free :( and then I got a new smartphone but have not figured out the camera-tapatalk integration. Also, I need to support picture size for some other forums I/we belong to that have picture size restrictions, so I'm doing the photobucket route for that purpose (of course my main loyalty is here!!!):D
007 - Thanks for the comments and suggestions. I appreciate your experienced straightforward approach to what we need for this trip!!:notworthy:
I lost the whole day today (well yesterday now that I look at the time...) to weather, barn chorses, and an apoointment in town.
Do real jeepers working on a build sleep?
Tapatalk had me a bit confused on pics too for a bit. Now it's a cakewalk.
Now I have an iPhone but...
If you just reply to a message as below, you won't have the ability to add pics.
But if you hit that + sign the you get the option to either take a pic or add one from camera roll on phone.
The camera shoots one, the landscape icon pulls from previous pics. That's what I use.
Either way you need a free Tapatalk account which it walks you through.
I love my tapatalk and phone, but was blown away when I sat down in front of my desktop. I totally forgot this site had so much! 100% of my time is on my phone because ,well its always with me.
Sent from my DROID RAZR HD using Tapatalk
007 - Thanks for the info - I will investigate further...
I have a new droid max (android) w/ kitkat on the same carrier as you.
But I use a special keyboard for vision impaired/old folks (ai type ez reader theme so I don't know if it will support this - I will check it out!) It :censored: to get old...enjoy what you can when you can!!! My career as an electrical engineer was cut short way too early for me - you never know what life will dish out your way. That's why this trip is a MUST for me one way or another...I will be there with something 4x4...;)
OK - OK it's snowing here again :bang::bang: - I'm on my way up to my desktop right now...:rolleyes:
Here to. Already got a foot today. Supposed to get another 3 to 6 inches. Im ready for Spring. ;)
Hey Pete - where is that stuff - I think I need some of those parts...:D
Especially the kayaks!...:eek:
I'm rooting for you, will be watching sounds like you guys have a lot of work ahead of you good luck :lpopcorn:
Finally some pics - most of the tear down pics are here in my gallery and thats boring so I'l just show some basic ones to ref where we got started:
Removing ugly fenders:
removinguglyleftfender_opt_zps5d038e79.webp "] removinguglyleftfender_opt_zps5d038e79.webp [/URL]
Fenders removed:
Firewall wiring mess:
Body Parts stored in the barn (sounds like a crime scene..:eek:)
Buick 231 V6 oddfire T86aa Dana 20 from the rat jeep:
And the Fully Kelly steel top complete with roof racks- not sure if we'll use it but it fit's the tub:
The next set of pictures will be from recent work...more to come...
Wow. I'm really lost on those fenders...
I love that fuse block, simple and accessible. I always said that the guy that decided it needed to be up under the dash deserved a slow painful death.:D
Alright now we have some pics. Time to gather up the Large popcorn and watch.:lpopcorn:
Those fenders have me interested. Im thinking they may be some old style Postal fenders. They have the lights on top of them like were on the top of Postals around here many years ago. Im going to lok into this and see what I can find. Id dump them for some classic CJ5 fenders myself and it doesnt sound like youve fallen in love with them either.
