1963 CJ-5 Dash Removal...Help!
acowherd
Mighty MO
2009 Dmax Tow Rig
2010 Camaro 760 Rwhp...
2008 JK Rubi Wife's Rig.....
1963?? Cj5 project Rig
:)Acowherd,
Keep in mind there are two bolts in the dash in each corner left & right above the foot well that need to come out..............just leave the dash fall towards you and support it via some wire off the windshield...............you do not have to cut the choke or throttle cables off.............they unscrew from the back........so do all the gauges & light switch...........there is enough room to get everything undone..............there is not enough wiring under there that you would be confused about on the return ...pretty simple.
If your pulling the motor just mark those ends...............take a bunch of pictures of areas like the ignition switch ETC.
What I would do is get yourself a bunch of plastic resealable bags and keep all the screws , nuts, bolts you take off in different bags that you should mark with a sharpie for location...............not a lot of stuff there but it makes your life much easier not to have to figure it out later.
:D:D:D:D
Thanks...that's a pic before I started, but I did happen on those hidden bolts! I glanced at the wires, and was hoping to see a quick connecter back there. I did try to unscrew the choke and throttle knobs and they would just turn. I was really wanting to save & reuse those knobs. The speedo looks to have the most wires, and I just don't want to jack nothing up.
Good info of the baggies. I have been taking plenty of pics of the whole process.
Keep the ideals & info coming. Thanks!
What I have always done is get a roll of tape and as I unhook each plug or wire I will wright what it went to on a strip of tape and put it on the wire.
Interior Dash Pad
