Diff 1979 CJ5 Drive Train Questions
Differentials
brucekr
Donator
Oregon
78 CJ5, 304, T18, ??, ??, D30
Definitely a 44 rear axle. If you need to buy a clutch it would be best just to take the old one with you to compare it. It really not a big deal mostly just making sure the spline count is the same.
The T-18 Transmission is a goodun'. So is the rear Dana 44 . Curious if it's an OEM from an '86 CJ7 , or if it's something else. Is the rear axle wider than the front, as far as how far out the tires protrude?
Looks like someone did a spring over axle conversion too. At the front end, do you have spring shackles at the front of the leaf springs, right below the bumper? Curious if they converted the shackles to the rear too.
Do you know what Transfer Case you have? Maybe something good switched there as well.
For u-joints, you're likely running standard Spicer 1310. The rear looks like it has the OEM drum brakes. The auto parts store kid will want a make, model and year of vehicle. Just tell them it's a '79 CJ5 and that should be ok for the u-joints and brake shoes.
The T18 transmission is a goodun'. So is the rear D44. Curious if it's an OEM from an '86 CJ7, or if it's something else. Is the rear axle wider than the front, as far as how far out the tires protrude?
Do you know what transfer case you have? Maybe something good switched there as well.
The Dana 44 rear seems to be the same width as the front from the eyeball check. It measures 45" from the flange on the axle housing to the opposite side flange. I need to read up on distinguishing different transfer cases or if there's a casting mark. Appreciate your feedback in both of my threads. It's extremely helpful.
