1983 CJ7 - 12V Hot While Crank and Run Wire
thundley57
Bakersfield, CA
1983 CJ7, 258 cu, Howell TBI upgrade
Hi all,
I'm installing the Howell TBI kit and need to find a "hot while crank and run" wire to power the ECM. Is there anybody out there that has already done this conversion and can direct me to the correct wire? I'm assuming it will be one of the wires off of the ignition switch?
Thanks!
Tom H.
Bakersfield, CA
1983 CJ7 AMC 258 i6 / 4.2l ci
Hi all,
Thanks!
Tom H.
Bakersfield, CA
1983 CJ7 258 ci
Here is a link that I used when installing mine, check item #33:
Howell TBI Throttle Body Fuel Injection Installation Jeep CJ Emissions
