1995 5.9 360 bolt up?
Stomper
Gold Bar Washington
1976 cj5 in corvette yellow,232 inline six(at the moment)3spd,front amd rear lockers,33's,soft top,
I was wondering if anyone knew if a 1995 360 has the same bolt pattern as the older ones?I found a 1995 360 for 350 dollars,I was thinking this would be pretty sweet for my CJ5 ! If this will bolt up I will probally spend the money for the 4 speed Transmission rather than the three speed I have in it now.Let me know what you guys think.Thanks,Stomper.
So different bolt pattern on the chrysler 360 I presume?
Yes, the bellhousing is different, you could always get a Chrysler Transmission , then your going to need mounts, adapters and other items.
Easiest swap is an AMC V8, it's almost a bolt in.
I've seen it done by a guy in Houston.
He used a NP435 granny 4 speed, Advanced Adapter, Dana 300 setup.
He fabbed his own motor mounts.
As usual not for rookies.;)
