2100 or 2150
2100 or 2150
hondo
california
1977 cj5 304v8, 46 cj2a farm jeep, 42 gpw restoration project, cj2a/cj3a new project
trying to id my carb so i can get a rebuild kit. not shure whether i have a motor craft 2100 or 2150, the tag is missing (of course). thanks for any help
Doesn't matter, you will get both rebuilding kits in one box. The tricky part is using the right pieces in your carb.
According to Mike's carburetor parts "Not sure if you have a 2100 or a 2150 carburetor. Notice that the back of the 2150 is usually straight where the 2100 is V'd in the back."
We had some problems with this too. There is a number code stamped on the base which can help. Maybe.. If the carb was turned in for rebuild then it may not tell you exactly what you have, but at least what the the base was from. Ours turned out to be from a '76 CJ.
Well this picture is small but the code is below the rusty nut. I found this on some mustang forum.
