225 dauntless v6 oddfire exhaust note question video posted
Lucasday
Kcmo
1971 cj5 renegade 2 paint code 999 trim 340. Big bad orange, 225 odd fire, t86aa 3 speed,Dana 18 single stick, dana 44 off set rear, dana 27 off set front, 4.89, Koenig pto, koenig pto winch. Production date May 1971
YouTube. This is a link to a YouTube video I just made tonight. I am wanting to know what you guys think, reason being it sounds odd as heck to me that one side sounds healthy and the other weak. When I bought the jeep it had a bad knock or more of a clang to it after worm up. I ended up buying a timing set ,new timing cover along with oil pump,water pump and other tune up parts. So I have been driving it around with no problems but can't get over the exhaust sound. The jeep starts up fine,timed, no smoke, pulls hard, easy to get up to speed easy 55 mph. Any thoughts of yours would be great. I pulled my valve cover tonight to check things out " pulled plugs turned by hand" all looks well.
:)You should do a compression check then also a leak down on all cylinders. If there fine your just hearing the odd fire sequence inherent with an Odd Fire motor.
Option: Change it to a later Buick Even Fire 231.....all of the external accessories will fit.
:D:D:D:D
I hear the the odd-fire is a great engine for the older CJs, due to its increased torque. I have seen them on the trail and in the sand where they work just great. That sound of course, sets them apart.
YouTube turns out I had an even fire cap on my odd fire motor. Runs great now. Thanks :cool:
is there a visible difference between the odd & even fire caps? I've got to run 92 octane and 0 degrees of timing to avoid knock, so now I'm wondering if this may be why.... ?
