258 stalls when warmed-up
Need some help / ideas please.
As a project I just picked up a 1980 CJ7 with a AMC 258 i6 / 4.2l ; over the last couple of weeks it started to run "rough." When through the simple stuff - new plugs, cap, rotor, fuel pump, fuel filter. It has now progressed to the point where it stalls when it is warm. It will run fine in high idle, but when it steps down it will run for probably 4 - 5 minutes and the stall. At that point it will re-start, but then stall again. If I let it sit for 30 minutes or so it will start right up and go through the whole cycle again. Any help would be appreciated.
bcmjw
bcmjw
