300 transfer case seal number
Fdpwr2a
NWMO
48 CJ2a ford I-6,T-90,D-18,Warn O/D pto winch
57 CJ5 buick v-6,SM420,D-18 Warn O/D
61 CJ5 buick turbo v-6 SM465,D300
77 CJ7 SBC 350 SM465,205
57 CJ5 Auburn trencher
What's the front output seal number? O'reilly's says they don't list any Transfer Case parts? Are both front and rear the same? Thanks fdpwr2a
The more I work on items like transmissions the more I'm becoming aware of the fact that there are multiple options as far as seals are concerned, Some arte better in different applications' than others. So, I don't really know if there is actually one seal number for anything anymore. A quick example comes to mind is single V.S. double lipped seals. Then there are seals with a sealant on the rim, seals with steel shells, seals with plastic or rubber rims, then there are double seals. All work, some are better than others.
My records, from when I did my 4:1 install shows this for both output shafts.
CR 15635
It's double lip seal. ;)
TCase Dana 20
Trans 81 CJ8
