I don't really think the grounding was bad on a new CJ, I think the grounding can be bad 40 years later. After all no mater what they say metal is metal and electricity will run through metal just fine. I would run the battery ground wire to a nice clean spot on the frame, from that spot run a battery cable with eyes on both ends to a bolt on the engine. It wouldn't hurt to run a similar cable between the heads, you will find empty threaded holes on the back the heads, I use those. Most battery cables will have an extra heavy gauge wire at the clamp. I use that wire to ground the body. From there you can go nuts running ground wires to the dash and maybe one to the rear of your CJ, but since electricity will run in metal I run a ground wire from a frame rail to the rear portion of the body. Where the tail lights are grounded is a good spot. A lot of folks like to run more ground wires all over the place, I'm not a believer, but they are and it certainly can give you piece of mind knowing that your CJ is well grounded. I'll also add a disclaimer, I live in the desert south west, but came from the Adirondacks so I know from what I speak. We don't have the rust you will be dealing with in Pa. While my frame is old and might have cracks in it, there is absolutely no rust on it.
