32/36 Weber DGEV flooding in one barrel only
76cj7chick
Old Time Jeeper
- Solutions
- 1
- WA
- 1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Any one know what would cause my new 32/36 DGEV 2 bbl weber to flood in only one barrel. (The secondary not primary?)
Here is my specs:
1976 CJ7 with AMC 258 i6 / 4.2l AMC 258 i6 / 4.2l straight six with a one barrel intake but I used an adapter (that was included in my carb package) to make it a 2 barrel.
Since the beginning the carb has flooded between the gaskets -adapter plate and lower carb area. I adjusted the idle mixture out 2 complete turns from bottom out. But when I shut off the jeep and look in the secondary barrel it is flooded. (Before adjusting the idle mixture It would spit out black smoke from the exhaust -which I assume indicates a rich gas mixture. After adjusting I don't notice the black smoke but it does stumble in idle a bit (haven't touched the idle or fast Idle screws yet...)
I did adjust the choke (3 screws but didn't hold open the throttle - perhaps this is causing my issue of flooding? Also, I get white "smoke" (fuel vapor?) coming out of the primary barrel -used to be both but now just notice in the one barrel.
I've read on line that the flooding my be caused by several things:
Float wrong/ bad
Vacuum leak
TIming issue
etc.
Where should I first start?
I also noticed that the two CTO switches on the engine block are not connected to anything nor are they plugged... Could this be a vacuum issue?
I wanted to add I've installed a NEW Fuel tank, Fuel filter with return nipple, fuel pump most hoses are new and have a fuel pressure regulator at 3.5 psi.
EDIT: Also is this a progressive or single action carb?
Any assistance would be soooo helpful. Thanks guys.
Here is my specs:
Float wrong/ bad
Vacuum leak
TIming issue
etc.
