4.56 or 4.88
4.56 or 4.88
Athens tx
77' cj-7 amc304 t-150 dana20 front d-30 rear d-44
I run 35" federals on the streets and 37" boggers on the trails. I like to pull my 17' flat bottom prodrive to the lake with the ole cj and I do lots of wheeling at parks wanting to know if I should gear it to 4.56 or 4.88 have 3.73s in her right now.
I would go with the 4.88
I have 4.88 on mine.
I run 4.27 35" tires. You won't be happy with 4.56 and 37" tires. You need to compromise on the street or the dirt. Good luck...
If you are still running the stock axles, the 4.88 pinion gear gets pretty small in the Dana 30 .
