4WD Shifter Linkage
Allen9878
- Media
- 13
- Central Wisconsin
- 1980 Jeep Cj5 Renegade
I258 1987 Engine
Aisin Warner Ax15 Transmission
Dana 300 Transfer Case
I just recently disassembled and reassembled my shifter linkages to remove the Transfer Case and realized there is a lot of slop in the rod that the shifter rotates on. I am wondering if anyone would guess if the rod itself is worn out or if its the aluminum holder(part of the Transfer Case ). Either way is there an easy fix? I will buy a new rod if thats the case, but otherwise maybe there are sleeve inserts to fix the wear?
Thanks for the insight!
