76,77 heater upgrade
Adamgs340
Barberton,oh
77 cj5 304 t150 dana 35 and model 20 dana20 tcase, 2006 wrangler X stock, 1967 buick gs340
Hi guys new here and just wanted to pass some info on that may help somebody. I have had a 77 CJ5 for a while and have made some upgrades and repairs to make it better since it's my daily ride. This thread pertains to my heater upgrade. I searched for a while and could only really find info on the 78 and up CJ's. As you guys know you use a standard gm blower motor and cage for these jeeps. The problem with 77 and back is that blower motor would spin the wrong direction. So I thought I was sol. So I work at a parts store and got out our parts books to seem if they made a motor that was the same as the common GM one but spun backwards. Well I found one the number is 35337. This one is the standard gm but spins the opposite direction. I cut out the mounting plate so the motor would drop in. Then I made a spacer out of 3/4 plywood and bolted this between they blower motor and the plate. The other issue with this is that there isn't any blower motor resister in this system so you really only have one speed. So what i did was there are two wires coming off the switch both of which have 12v to them. The wire that was hot when the switch was in the first position goes through a standard Chrysler ignition ceramic resister then to the blower motor. The second wire goes directly to the blower motor. I made a t connector at the blower motor to accept both wires. This set up gives you a two speed high out put (roughly double the volume on high) heater set up for the 77-76 cj's. Somebody else may have already figured this out but I could not find it. I don't know what the application of the blower motor is but any parts store should be able to cross that number to there brand. That particular number is from advanced. Hope this helps somebody out. Last week here in NE Ohio is was 17 below with the wind chill and I had defrosted window all the way across and was warm with and ill fitting soft top. If I can help anybody with this by answering questions let me know
Thanks Adam
Specs
Part #35337 – 93-95 GM trucks 92-93 S-10/Jimmy
Voltage
12
Rotation
CCW
Shaft Dia.
5/16"
Shaft Length
1-5/16"
Motor Length
4-5/16"
Motor Dia.
3-1/4"
Connector Type
1 Spade Terminal
Stock replacement 77 CJ5 Part # 35500
Voltage
12
Rotation
REV
Shaft Dia.
5/16"
Shaft Length
2-7/8"
Motor Length
4"
Motor Dia.
3"
Stud Distance
2-5/16"
Connector Type
2 Lead Wires
Great, one more project to add to the list :rolleyes:
Hey Hack, got a part number for the fan motor you got bought? I clicked the link and got: "The page you requested cannot be found!"
Looked at their inventory and they have quite a few to choose from (for a dummy like me :D).
Link just was to get you to their site. I physically called them (a loooong time ago) and provided them with the dimensions, etc. of the motor. They were able to provide one that 'bolted in' to the existing sheet metal. Part number back then was: 100-221 (but this was 1999). Blower wheel part number: 35609. NAPA also carries the blower wheel, but I don't have their part number.
I had always figured the GM motor would run backward and never really took it any farther. I, for one, very much appreciate this information. Is this number a GM number or is this the supply catalogue number??:cool:
Cool, thanks! As soon as I get my coal burner out of the shop, I got me another project to do!
Order the blower wheel. I'm 99% certain you will break the original....
$100.00
  50.0%
