79 cj5 skid plate
79 cj5 skid plate
radman
South Dakota
79 CJ5, 304, T150, Dana 20, Corp 20, Superior one piece axles
2012 JK Rubicon 2 door
help... i'm having a problem with the devise that connects the xfer case and the skid plate... took it apart a month ago and well i didn't pay close attention to the way the rubber parts work. a picture or diagram would be very helpful...thanks in advance
I'm in a similar place but I am trying to piece together my mutant pile. Being new to these beasts I could use a pic of a '76 and '79 if they are different. When I center my skid plate it does not line up with the mount holes. But, it does when it is shifted to the driver side.:confused:
I have a '79 CJ5 what part are you needing a picture of?
The skid plate itself? It'll be tomorrow around 7 - 8pm before I could get a pic
but will if I can.
For me I would need a pic straight up at which holes on the skid plate are used for bolting to the mount.
it's the rubber bushing and bolt assembly that i need to see. again, thanks
hey longhorn, you rule... thank you for the verrrrry informative pix!
I second that. looks like my mount bracket is on wrong. If I am seeing this correct.
