80 cj7 304 v8 with GM 4 pin hei conversion question
suburban99
Mission City, British Columbia, Canada
1980 CJ7 304 V8
2011 Silverado 4x4
2004.5 Dodge Cummins Diesel
1997 Porsche Boxster
I removed the duraspark module and replaced it with a GM 4pin hei module.
Jeep starts and runs better until it gets warmed up then it seems to lack power.
I am running an MSD distributor and a MSD blaster coil and am wondering if I need a ballast resistor to protect the coil...?
The ballast resistor is not needed with the blaster coil. (The ignition module doesn't matter)
You must login or register to view hidden content on this page.
