83 cj7 auto trans shifter
elcates
Milan,TN
1983 cj7 auto trans, tilt wheel , detroit front and rear.
I have a problem with my shifter, its not very smooth.:confused: i like to keep it stock as much as possible, should i do a cable shifter from the column or buy a floor shifter:)
Have you checked and lubed the linkage in it now? Any idea where it's not being smooth at? (column or Transmission .)
Did check it was hitting the headers, and i put a new bushing in the Transmission shifter bracket helped some, I was wondering if any one has used a cable shifter before. Thanks for the reply:)
