84 CJ7 35’s, all metal, lockers, from CO
Weezykid
1984 CJ7 AMC 258 i6 / 4.2l 5spd steel body, excellent frame. Dana 30 front, AMC20 rear with 1pc sierra axles. New front brakes in April, rear brakes have about 800 miles on them. Has lockrights front and rear, still have factory spiders. New spicer balljoints, new spicer axle joints.
New repo dash pad, new Bestop seats all around, new rear seat belts. Also has new dual diaphragm power brake booster. New power steering pump, Lares Rock crawler box, More hd box mount and brace. Borgensen steering shaft. Column has a broken cover but I have a really nice XJ column I haven’t swapped in yet.
AMC 258 i6 / 4.2l received new oil pump, water pump, timing chain, belts and hoses and all new gaskets. Changed the rear main at the same time. Has Weber 2barrel conversion and HEI distributor. Plugs, wires, cap, rotor less than 1500miles. Aluminum valve cover has slight gasket leak. New radiator hoses and heater hoses.
5spd shifts great and when the inspection plate was off the flywheel looked like it may be newer. Dana 300 and I have a full seal kit extra to go with.
35” Cooper SST tires on 15x8 ARE aluminum wheels, Philips led head lights, new led tail lights. Stainless steel extended brake lines, OME YJ lift had springs, Bilstein 5100 shocks, RRO YJ swap kit. Fishbone shackles.
Hella lights. Smittybuilt back bumper and spare tire carrier. Extra poly body mounts.
Newer 15 gal gas tank, new fill hose and vent hose. Genright Alum corners, genright steel rocker guards with rails.
This came from Colorado so it has minimal rust, frame is clean! Speedo says 6500 miles, title matches but maybe 106k? Comes with a bikini top, hard top, full doors and brand new soft doors that have not been installed.
Asking $12,500 obo
Asking $12,500 obo
