84 CJ7 V8 swap
NorthwestCJer
- Spokane Washington
- 1984 CJ7
D30 4.10's locker, M20 4.10's
one peice axles locker,
258 with MC2100 and K&N,
Nutter bipass, 8mm wires,
Or-Fab cage,
Tuffy console,
Bestop seats,
GM power steering,
4 inch Rancho lift, Edlebrock shocks,
On board Air,
Smittybuilt winch bumper,
M8000 Warn, 10k Synthetic,
Swing tire carrier with Hi-Lift,
extra fuel, shovel, chainsaw,
33" KM2's on 8 inch rims,
Bestop Super Top!
I do not post a lot on forums! I have done a quite a bit of mods to many Jeeps I have owned and many buddies rigs.
This is the first time I have done a V8 swap using a AMC V8.
I thought many that are considering this swap might want to know this info. It is things that I have not seen before.
You will here lots of people say that AMC I6 to a AMC V8 is a bolt in swap.
You will also here that the drivers side motor mount is the same.
I have my 13th open tubed Jeep vehicle. A 1984 CJ7 .
Factory (and hurting) AMC 258 i6 / 4.2l /AMC 258 i6 / 4.2l .
These statements are not completely correct.
http://i678.photobucket.com/albums/...C-357E-4FAA-8539-8FE4C8E9836B_zps2m7wtovk.jpg
http://i678.photobucket.com/albums/...C-A109-4FAF-8DA8-44BD09ABEFA0_zpsegizo3ol.jpg
http://i678.photobucket.com/albums/...9-DB45-492D-A397-8C9FF145AB65_zpsvkg1akl3.jpg
The fact is, you could use both motor mounts if you drill them out. The Drivers side mount does not have the holes drilled for the V8 mount.
I also used 1974 CJ5 factory motor mounts and the frame bolt pattern is slightly different.
http://i678.photobucket.com/albums/...0-14F1-4757-ACD4-CF0F9AED12C8_zpsqnodv2r4.jpg
This bracket needs to be cut off the firewall. It is a heat guard for the I6.
In addition. the Transmission needs to come ahead about tow inches. This was not an issue for me. My T177 (yes T177) had an additional bolt pattern that allowed me to move it forward on the belly pan without modifications.
Oh, and I said T177 because a lot of CJ's that were produced with the 2.72 diff gearing actually came with the lower first gear T177 and not the T-176 .
http://i678.photobucket.com/albums/...4-4EBD-4FEC-9AD4-2B4780FC0E08_zpsygjpfiry.jpg
http://i678.photobucket.com/albums/...F-2CA1-48C9-A928-B1052C5FEF86_zpsrwhekj3u.jpg
I hope this helps some of you.
I will follow up with a final post and pick.
