85 CJ7 4 cylinder
85 CJ7 4 cylinder
fzsk4p
Michigan
Ground up YJ.
Looking to get a CJ
Hi folks,
as my avatar mentions....Looking for a CJ to rebuild.........Found an 85 CJ7 on CL but it is a 4 cylinder.
Want to get educated before I make an offer/look on it.
Could be an AMC 4 or an Iron Duke. Not sure when the change over year(s) were.
Would the axles be the typical Dana 30 /AMC20 as found in a 6 cylinder ?
Transmission /Transfer Case ?
Likely swap in a 4.X but am wondering abut the rest of the drivetrain.
IE did Jeep use a specific 4 cylinder drivetrain that would require a different Transmission /Transfer Case for a 4.X swap ?
How about differences between the AMC 4 vs. the Iron Duke driveline ?
My searching thus far has raised more questions/confusion then answers.
A link would be fine.
Thanks !! :notworthy:
Is it an auto or a manual?
This is what I had to do when I swapped out the 2.5 for a AMC 258 i6 / 4.2l (Kept the T-5 manual) :
I first had to locate a bell housing from a 6cyl CJ that would work with my T-5 . Luckily, being as the AMC 258 i6 / 4.2l /T-5 was an option, that wasn't difficult. The 2.5 and the AMC 258 i6 / 4.2l do not share the same engine bolt pattern, so this is required.
Next I had to swap out the 10 spline input shaft with a 14 spline on the T-5 to correspond with the AMC 258 i6 / 4.2l flywheel clutch assembly.
The AMC 258 i6 / 4.2l sits back further in the engine compartment then the 4cyl, so the whole drivetrain moves back about 2 inches. This requires shortening and lengthening the drivelines and moving the tranny crossmember back to the next set of holes in the frame.
You will need a 6 cylinder radiator, and if you use a "newer year" AMC 258 i6 / 4.2l with a clutchfan, you must use a radiator with the off-centered cap. The older CJ's used a radiator with a centered cap that was deeper and it will interfere with the fan. Be sure to use a shroud also.
You can re-use the stock ignition control module...not sure about ECM as I de-smogged mine prior to a swap and none of it was functional anymore.
4cyl equiped CJ's had 4.10 gearing from the factory...a definate plus.
Thanks guys,
Good information provided.
Likely do simple OBD 1 EFI 4.X engine. Little bits of information like the radiator are priceless, thanks again.
Jim, you mention the AMC 258 i6 / 4.2l setting back a couple inches. No problem with that. But are the engine mounts (frame side) the same for a 4 vs a 6 ?
On a YJ the 4 cylinder mounts are different in design AND location then the 6. So I am curious about a CJ application.
The 4 cylinder is appealing if for no other reason the 4.10`s in the axles. Even more so now that I understand the Dana 300 TC is common between the 4 and 6.
A 4.X combined with a decent 4/5 speed. Running 33`s would be about right for what I want to do. `56`s would be better but could live with the `10`s.
Thanks guys,
Yes, the 4cyl frame brackets are different from the 6cyl brackets. I believe I have a set of 6cyl brackets out in my "spare parts". If and when you pull the trigger on a swap, and you need the mounts, just let me know.
AMC used a lot of the same parts between the 4 and 6cyl equiped Jeeps. The tranny's become an issue because of the spline difference with the input shaft, but for $125 you can swap that out if you are inclined to keep the T-4 /T-5 .
Are you considering swapping in a 4.0 or a FI AMC 258 i6 / 4.2l ?
Jim,
thanks for the info/offer. Knowing what you and Elwood have provided in terms of information has opened a lot of doors.
Not afraid of tearing into a Transmission or TC. If nothing else, fresh seals, bearings, syncro`s and the like will provide familiarity and confidence.
Engine wise....Likely a 4.0 with an OBD 1 FI system will be good enough. Maybe another stroker (albeit a bit tamer) like in the YJ is a consideration. Have the harnesses and ECM to do it.
Although a AMC 258 i6 / 4.2l with a 4.0 head and OBD 1 is not out of the question.
Plenty of options. Will weigh it all out when the time comes.
The most important tool is the knowledge that the 4 and 6 cylinder CJ`s carry so many common parts.
You and Elwood have help immensely.
Some parts like radiators an expendable items
Oh heck...I just remembered I have a radiator also. I bought it brand new several years ago when I swapped in my AMC 258 i6 / 4.2l and other then the usual bent fins, it's in perfect condition.
It's been boxed up and essentially ready to ship ever since I pulled it to install a bigger radiator for my 401 swap 4 years ago. I'll give you a really good deal on that also if/when the time comes.
I really like the 4.0 headswap on a AMC 258 i6 / 4.2l . I was completely amazed when I did my conversion, at the amount of power and torque I gained.
I know a lot of people prefer the straight up 4.0 route, but you get stroker-like qualities using the AMC 258 i6 / 4.2l bottom end.
I would happily still be running my 4.0/AMC 258 i6 / 4.2l hybrid if the block hadn't given out on me :(
If I had another CJ to mess around with, I think I would build another hybrid. Really like the inline 6 and the diversity it offers.
i just went through the same engine swap. i had the same engine and drive line just like you. you almost need a parts jeep with a AMC 258 i6 / 4.2l to make what you want happen. i know for a fact the motor mounts, bell house, and input shaft are not compatible. the wire harness is shorter. after i put the AMC 258 i6 / 4.2l i used a T-4 tranny out of a AMC 258 i6 / 4.2l that engine then the AMC 258 i6 / 4.2l blew up. after pricing out how much it was to rebuild the AMC 258 i6 / 4.2l it was cheeper to make it fuel injected. then i put a 4.0l efi engine in the same jeep. and that was definitely the best way to go. at the end of my project i wish i had put it in right off the bat.
