A Crash Course In Soldering and Modifying/Repairing Harnesses for Beginner Jeepers
ThisGuyUKnow
Full Time Jeeper
Featured
Harleysville, PA
1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
Excellent write up.. Only thing is its nothing like welding. When i solder up the splices for the head light harnesses I place the gun on the far end of the connector. Once its hot enough the solder will pull all the way through. Same idea as sweating copper pipes.
Thanks jimbo, I'll ask a mod to remove that comment to avoid confusion. You want the object you are soldering to get hot enough to accept the solder so that there is no space between the two objects you are soldering together, whether that is two wires or a wire and a butt connector or whatever. If I understand what you are saying you use a butt style connector, and place solder through it? That is what I was trying to imply that one should do if they use a similar connector, and to get out of the habit of simply crimping connections.
I've been meaning to do this write up a while for our members who aren't as experienced as some of us to hopefully give a basic understanding, and hopefully help them to avoid becoming, the dreaded PO.
If I may add a point, you can't buy too big a soldering iron. the little pencil irons are fine if you are doing PC boards but for anything larger than 26 ga wire you need at least a 50 watt soldering gun. I think mine is a 75 watt. You look to be using a suitable iron. I am also partial to the sealing heat shrink, splices and connectors. For best long term results, keep in mind that soldering flux is corrosive and should be cleaned off before the shrink is put in place.
Feel free to remove this if it gets in the way of your "sticky".:D
Definitely not "in the way". This thread should exist so that those with little to no experience can get the info they need in one spot.
Good point on the iron size.
I use a bare steel but connector. I mechanically crimp em then place my 1942 model soldering gun.. It humms and vibrates when you pull the trigger.. In the middle of the connector. Once it's on for about 30 seconds I'll touch the rosin core solder to the end and the solder will get sucked in. Then I'll touch it to the ther side. Then apply the shrink wrap.
good write up, I personally like doing wiring myself. Good job dude. I did a similar write up on removing bolts
Thanks for the write up. I just tried it out and it works awesome. Thank you
Fantastic explanation, guys. I've got a tangled mess under my dash that needs tending to...
Sent from my GT-I9152 using Tapatalk
