a few MC2100 questions
stoney bones
I've just replaced my carter bbd with the mc2100 as some of you may already know.
it started right up and will run. however it was idling up then idling down slightly...as if a wave. i switched a couple vac lines and it now runs steady. but, after driving down the road about a mile i was coming to a stop sign. it died while downshifting into first. re-started no problem but kinda had to give it a little gas to keep it from stalling again. i turned around went back to the drive way and while down shifting into third it started popping. not real loud gun shot sounding but just quieter, quicker pops and then again while down shifting into 1st to turn into the driveway it died.
it restarts and will run fine other than that.
im in the midst of changing it over to a rear pull throttle as to be more efficient and get rid of the bracket and arms. in its current setup there is no free play and the movement is not very smooth feeling.
any ideas where to start?
