A good day
A good day
IOPort51
Garland Texas
1977 cj-5
2006 Toyota Tacoma
I guess I could put this in "what I did" just too lazy to look for it. re learned a valuable lesson today, always check electrical parts before you install them. Especially if they are made by Crown and X2 if they are going to be a major PITA to re place. A perfect example would be the pick up tube/ gauge sending unit in the fuel tank. I think everybody gets the picture?
I also did something unique to my experience, I let the smoke out of the coil in a 50 amp Bosh relay. I have no clue how. After checking the low beam headlight connections, both hot and ground , every connector , fuse and solder joint to no success I decided that smoking a relay was not as impossible as I considered it to be. sure enough, crashed and burned, replaced and there was light and it was good. I actually have plans to pull it out of the garage tomorrow and drive it around the block.:D
Be still my heart!!:grinjeep:
