Air Cleaner
Air Cleaner
GoldenEagle36
SW Pennsylvania
1977 cj7 Golden Eagle 304,automatic, Quadra-trac, full restoration just "finished." 4 inch superlift, lift shackles in the front, sitting on some KM2 Mud terrians
1999 tj 4 cylinder ax5 trans 3 inches lift 31s
1956 Dj3a all original except axles and engine, Hurricane 4 cyl. 4x4 conversion, 27,500 original miles 58 Jeep-A-Trench cj5 8000 miles.
i wanted to change the carburetor on my AMC 304 to a 4 barrel, if i do will i be able to keep the stock air cleaner on it? Thanks
If the two carbs have the same filter seat diameter, 5 1/4", then it will work on both.
