ALT belt out of alignment
ar78cj7
NWAR
78cj7/258/th400/quadratec w reduction/howell fuel injection/old man emu suspension/2in body lift/electric fans/
Hello
I put a high amp alt on my 78cj7 and my belt is squaling bad.
Would any of you guys know a good adjustable alt bracket?
It was actually a Premier Power Welder addition
Chris
Hello
Chris
PS: those people at Premier Power are Very nice!!
and also at Howell fuel injection
MSD tech line in AZ not so much!
Thanks for that tid bit of info
what if i left out the part about "Premier Power Welder addition" would it go in this forum?
if not do i re post it or move it?
chris
i thought it was part of my engine
Setting up for a dual drive belt would help. I would think this would be a familiar topic for the guys at PPW.
i know but they wont answear the phone right now
thought someone would have similar problem
I know but they wont answer the phone right now.
thought someone would have similar problem.
Where would be a good place to get a duel belt drive?
chris
Hi output alt's have a problem with V belts and in the best possible world a serpentine belt would be the system of choice.
You may try an "AX" belt rather than the "4L" belt that most automobiles use. You will have to go to a bearing supply to get an "AX" the guy at the auto parts counter will just give you a blank look when you ask for one. "A" belts are the same angle and width as 4Ls but they have a deeper profile, the X means segmented so it goes around the small pulley easier.:cool:
This is the belt I run, no squealing unless my belt is loose....hint hint.
Hello
Chris
Chris, my '80 came with a dual pulley. From the attached factory manual, this must have been common. Maybe some junkyard spelunking would get you a double-belt pulley, tightened well and with good belt dressing on it.
I have since this photo added a brace from the lower bracket bolt to an abandoned bolt hole in the head from the now-departed A/C compressor. A/C was sorta not very efficient with all the holes in my CJ7 floor, dash, and the muffler head coming up just behind driver and pax chair. Like to run with doors detached.
