Aluminum Head Cover oil cap
228jeeper
- Ocean Springs, MS
- 86 CJ-7, 258, Desmogged, 4 speed T-176, Carter-Weber 2731, headers (no idea what kind), K&N Air Cleaner. Everything else stock as near as I can tell
I repaired a leaky valve cover gasket and was still finding some oil in the driveway. When I replaced the valve cover gasket, I cleaned the valve cover as good as I could. Now it seems that there is oil coming from under the oil filler cap and onto the valve cover. It is the press in type, not threaded. The one closer to the firewall has the same problem, but it is a bit smaller. When you pull it off and look at the underside, in the center of the shaft that fits into the hole in the valve cover, the aluminum(?) is pushed in like poking a hole in the top of an aluminum can. Could this be my issue? Any suggestions would be appreciated. I will try to post pics later. Thanks.
