Misc AMC 20 One piece shaft bearings
Tim_Coble
Donator
Featured
Alabama
76 CJ5, 304, T150, D20, AMC20, D30
So, I'm an idiot - I watched the videos, read the forums and still screwed up. One of my backing plates was put on inside out.
I managed to cut off the press ring and bearing without too much drama after kicking myself for several minutes when I realized what I had done. But now, my question is what bearing set to get. Are the bearings and press ring the same as the two-piece original?
Amazon has this set: "Yukon Gear & Axle (AK M20-1PIECE) Axle Bearing & Seal Kit for AMC Model 20 Rear Differential". Yukon's website doesn't specifically say the kit is for a one piece. They sell the one-piece kits but none of the bearing kits call out the axle type.
Thanks in advance.
Your not the only one I know who has had a problem like this. Unfortunately the WEB site doesn't show what you need as a package but I know if you call them they can make one up and ship it out to you or acknowledge that the kit listed is for the one piece.
It's going to take a tech line call.
So you have a Yukon or a Moser or some other 1 piece axle ?
I got mine from Moser.
