At last Rebuilding Engine, wich items to change from stock?
wmichelli
Miami
Cj7 jeep, 1986 no mods . Dana 44.
Ok Guys. Time to take measures. Decided to rebuild my AMC 258 i6 / 4.2l engine from stock. The question is simple: Any advices about wich parts can i replace better than stock or take advantage to do things that could be impossible after engine back in site.Example: Energy poly engine mounts? Thanks. Is one in a life time chance to see empty engine space.
Thanks in advance.
When I find a spare AMC 258 i6 / 4.2l to build, I am going to build it to VAM specs. 200hp and 280ft lbs. And still be a reliable driver.:)
Do an RV cam and bearings. Drill and tap the head bolt holes to 1/2 inch, if not already.This gets you ready for the 4.0 head.:cool:
Priceg: what RPM is this 200 hp,280 ft/lb' happening?
2200rpm
