    Thank you for your support!
Bikini Loops
Bikini Loops
007
Crazy Sr. Respected Jeeper
Reno, NV
1977 CJ-7 Renegade (Daisy Jane), Levis trim, 304, TH400, BW1339 (MM), D30/Auburn Max, AMC20/Detroit/G2's, 4.88's, 33" BFG MT KM2's, Edelbrock Performer intake, Holley Sniper 4bbl EFI, MSD6, MSD ProBillet distributor, OME shocks, 4" ProComp lift.
Where can I find the flat loops that you tie the bikini top to the rear corners?
Footman loops? Quadratec, 4wd hardware, Cheapest that i've found is ebay.
Tractor Supply, Big R, etc in the horse section.
Any good hardware or marine supply store. :chug:
