Blinkers and Brake lights won't work
AeroMoto
So my brake lights and blinkers aren't working on my 73 CJ5 . Has a painless wiring harness. I found that there's a short to ground on both the rear blinker circuits but not on the brake circuit. Didn't check the front blinkers. The fuse for the blinkers was blown, although I was messing around in the fuse box and might have swapped out a blown horn fuse, I don't remember.
So I'm guessing that there shouldn't be a short to ground...
Not sure why the brKe lights aren't working, any thoughts? My plan is to try to track down the short to ground, hopefully finding someplace where it rubbed thought the wire insulation.
