Body Mount Bolt Specs
Tin Medic
Ft. Carson
85 CJ-7 Renegade:
Fuel Injected 4.2L I6/T5/D300
D30 with ARB Air Locker, AMC 20 w/Posi
Warn 8000 LB winch
VIAIR Onboard Air System
33x12.5x15 Goodyear MT/R's
Kenwood head Unit
Hella E-Code Lights
Looking for the specs (length, thread) on the body mount bolt. Replacing the mount and want to put new bolts in.
Is there a reason you can't gather that info from the bolts your removing? If for whatever reason you can't we need more info, do you have stock mounts or lifted?
Stock mounts but I havent pulled them yet, want to get the bolts before I start.
If it were me, I'd want to be positive on the length and thread pitch so I'd suggest pulling one bolt to rule out any doubt.
Tin Medic, I would think a grade 5 replacement bolt would work just fine. For the length, have a minumum of the thread diameter for engagement into the mating thread, like with a 7/16" bolt you need 7/16" length of thread into the nut.
