Brake booster
lmk3087
If there is no brake booster, where should the manifold vacuum go? Should I just plug it?
Also, can a brake booster be installed?
Most people are using YJ MC. I think its 95 that works best due to not having to bend the brake lines since they are on the correct size. I purchased everything on ebay for $75.
The yj booster, although all years except 95 havthe single diaphram, out perform the cj booster. If you are running larger than stock tires often it's hard to stop your cj. I just installed a yj booster and I will be sure to report here as soon as it is road tested(may be a while my engine has the head off).Just curious... why does it seem like most people put in the YJ booster? Would one from a CJ work as well?
