brake leak? Differential leak? Both?
WarEagle
- Little Rock, AR
- Current:
'74 CJ5 - 258 I6, T14, Dana 20 TCase, Dana 30, Dana 44
Daily Driver: 2019 Volvo T6 XC60... Grocery getter...
Retired:
'81 CJ5 - 258 I6, T176, Dana 300, Dana 30, AMC 20
Alright, so I had the rear of the CJ on jack stands since Friday (about 4-5 days) and finally finished cleaning up the back and the changing the rear oil. New wheels and tires came in so I installed them in the back and went to install them in the front but noticed some oil that looks like it is leaking from the front differential cover. Fine, I was going to change the oil and replace the seal up there anyway but then I noticed a good amount of oil on the inside of both front tires...
I took off the front wheels and tires and looked around the front drums and hubs and can't really tell where it is coming from. I plan on getting under there and cleaning everything up and then letting it sit for a few days to watch and see if I can tell where exactly it is coming from but are there known culprits I should be aware of? Could the oil just be a symptom of the CJ being jacked up in the rear and left tipped forward for a few days?
