Carb swap
Carb swap
1981CJ5
Edgefield,SC
Stock 1981 CJ-5 with GM 151 ci.
Will an autolite 2100 carb fit on a GM 151 inline 4 instead of the Rochester 2SE carb with out modifications?
Waaaaaay to much carb for that engine. I would say you should stick with the Rochester. IMO:cool:
Will an autolite 2100 carb fit on a 151 inline 4 instead of the Rochester 2SE carb with out modifications?
A Stromburg or a single barrel Weber...
I would keep the Rochester But it is missing parts. I was wondering about the Autolite because they are availiable in junk yards in my area cheap. Are there any other models of carbs to consider before i get a rebuilt one?
the bolt pattern for the rochester is different than the motorcraft and holley bolt pattern and im yet to find a adapter plate. i think im going to just make one for it :D
Thats a good idea. I still havent decided what to do about my carb. I don't know if its worth it to rebuild it or not
$100.00
  50.0%
