Carb swap?
Carb swap?
Buuushman
Kihei, Hawaii
77' CJ-5, 360 c.i. motor, T-176 trans, D-300 transfer case w\ twin sticks, Dana 30 front, A.M.C. 20 rear w/ 4.10's, solid axles & trac-lok, 2.5" lift Y.J. springs.
Do you think this would be a good upgrade from my holley 2 bbl 300 cfm carb?
600 cfm too much? not a reliable carb? Just ran across it on C.L.
EDELBROCK Chevy Carb
Thanks, Bushman
a 600 CFM vacuum secondary carb will work, but a 470 CFM would be better.;)
Thanks for the link- it looks like the 470 would be the way to go but the chances of finding a used truck avenger around here that I can afford- if at all- are pretty slim. do you think the Edelbrock 1404 500 cfm would still be too much? I may have better luck finding one of those.
thanks - Bush
thanks - Bush
IMHO 500 CFM would be fine.
I've been running Holleys since I started out, I don't have anything against the Carter AFB/ Edlebrock performer. I just don't have any experence.
