Caster and wedges
Hedgehog
Always Off-Roading Jeeper
- Tucson/Marana Arizona
- -1975 Jeep CJ5, 360 V8, Headers, Duel Exhaust,T15 transmission, D-20 Transfer case, Twin Stick Conversion, Warn 8274 Winch
Funny how these things work out. My old 1975 CJ drum front axle ran just fine with all caster wedges removed. 75 mph, no problem, the steering was light, but easily doable. So what do I go and do. I pulled the 1975 drum axle off and transplanted in a 1978 disk axle. Thinking that the original ran acceptably with no wedges and with nothing changing (the same springs, the same shocks, the same steering gear box) wedges were left out.
The CJ drove terribly. So off to the alignment shop she went. The alignment mechanic said that everything was tight, I only had a little over 1* of caster angle. As expected the toe-in was off so he adjusted it. He said, drive it, it's a lot better, but it would be better with at least 4* more caster. I drove it home and found that the steering was better, but FAR from what it once was. So with his words ringing in my ears I stopped by Willys Works for some wedges and yes Lumpy some longer spring shackle bolts. After looking at his wedges and being the American I am, and remembering some posts here, I bought a set of 6* wedges. After all if 4* will work, 6* must be better.
Honestly, Rob and Willys Works is a bit dubious about the 6* wedges. He said that I should ask you guys this question.
What happens when you have too much caster angle or to much wedge?
Hmmmmmm, this should not be in the Drivetrain Forum it should be in the Steering Forum.
again.
