cj died
You say you turn the key an nothing happens.
If the engine won't even crank over then the problem is one of the following: the Battery, the starter, the starter solenoid or a connection between these components. You say you say you replaced the starter. Next I would check the battery connection. This often corrodes up. Then the battery may work for low current things such as lights. The starter needs very high current. Remove both cables on the battery and use a terminal cleaner to scrape the posts and the cable ends. If it still wont start I say it's the battery. You said it is ok but I wouldn't be so sure. It is very easy to remove. Take it to an auto parts store and they can test it. As I said it may work for low current devices but still not be able to start the engine.
When i was about 15 I learned to "hot wire" a car. With the obvious benefits aside, this gives a good working understanding of what is actually required to make the engine run. I guess this is one more piece of "tribal knowledge" that has been lost.
The first thing I would do is "jump" the solenoid to see if it was just a loose/corroded ignition wire.
The last time I had to deal with a dead battery was because the brake switch worked loose and the brake lights stayed on until the battery went dead.
