CJ7 Hard door replacement window
GERK
Carnelian Bay
1981 CJ7
1972 ScoutII
1972 ScoutII
2000 Ford Excursion
8 Other Scouts in the past year
I have a cracked slider glass on my Cj hard door. Its the one that slides.
Any tips on removing and replacing the glass?
Ive taken the frame out, but I do not see how to get the glass out.
Any help is greatly appreciated
You must have aftermarket doors on your Jeep so if you could post some pics I might be able to help you out.
So after looking at your pics it looks like there is a trim ring around the inside that is screwed on that has a split at the front. you should be able to pull that ring off then the outer part with the glass needs to be removed from the door. It will have some sort of sealer between the frame and door that will make it tough to remove it. The best way I have found is to take a hard putty knife and push it in there and gently pry the frame from the door. Once you get it apart you should see how to get the glass out.
I actually already did all of that. It was quite easy. I just don't see another way to open it again to get the glass out.
Then post pics of the frame out of the door. And I mean from the side that buts up to the door.
You are right. If it is screwed to the frame remove it and that should let you open it up enough to get the glass out. then when you go to a glass shop to get a new one see if they can get a temperd one made for you it will hold up better.
Awesome. Thx for getting the problem to stare me right in the face.
I really appreciate it
