To celebrate the 4th of July, starting today (07/01/2025) all User Upgrades will be reduced by 10% (thru 07/08/2025) To use this special coupon use the code 2025-4th-10percent at check out. If you are already a supporter your existing package will be extended. Thank you for your support!
Trying to adjust clutch (new) on a 61 CJ5 , 4 cylinder, has a cable, can turn cleavis, to shorten, but can not get it back on the mount, have to turn it back down, resulting in no adjustment. Is there a way to hold it, like when you push in the clutch, so it will go back on the mount? Thanks
Found 4 or 5 holes in the bellhousing just under where the cable goes in, put a screw driver in and was able to hold the clutch fork fowared, making the cable go on the mounting.
