Clutch bolts?
derf
- Cedar Rapids, IA
- 1984 CJ7 - 5.3/4L60E/Atlas4spd/D44/9" - In Progress
1984 GW - 360/TF727/NP229/D44/M23 - NP242 swap in progress
1986 J10 - 360/TF727/NP208/D44/D60 - 700R4 upgrade in the works
So I'm getting ready to bolt up the clutch on the 401 for the CJ. I have the flywheel, clutch disc and pressure plate. I don't have any bolts to attach the pressure plate to the flywheel.
What would be good bolts to use? Grade 5? Grade 8? What about washers?
What did the factory use on the pressure plate?
