Clutch grind
Flex BT
- Chesterfield, VA
- 1981 CJ7. I6, Weber 38/38 with TEAMRUSH upgrade. T5, Dana 300TC, Dana 30 / AMC 20, True trac w/ 4.10s. 33" All terrains
Blue and rust colored.
I just got my '81 CJ a few weeks ago. I've learned a ton from this site already so thanks.
It doesn't always happen, but most of the time when shifting a grinding / vibrating happens when I'm bringing the clutch back up and it stops when the clutch is fully released. The PO told me he had a new clutch professionally installed, is this a clutch issue or Transmission ? I think it's a T-4 in there but I'm not sure. I changed the transmission oil today which came out looking pretty clean. I put in a quart of synchromesh and a quart of ATF and it didn't make any difference. I thought I read that the transmission took 6.5 pints but it was overflowing after just the two quarts. In any case, it didn't make any difference whatsoever. Any ideas on the cause of the grind and how to fix it?
