Cluth Issues
Cluth Issues
raywagoner
Colorado
Does anyone know where I can find the right part information for the clutch pedal? Mine keeps disengaging from the linkage on the inside of the vehicle. It had a little snap ring on it but it won't hold anymore. From everything I can find, that doesn't look like the right part for the job. I'm pretty sure it has an aftermarket hydraulic clutch and the pressure point at the firewall where the rod from the pedal engages is where the problem is. Any ideas?:eek:
I have seen that diagram before. I don't think it is my clutch. It just has a single rod from the pedal to the unit in the firewall. That unit runs a line to the master cylinder under the hood mounted on the firewall.
You mean the rod is separating from the master cylinder?
I'm not positive but I don't think the rod in the master cylinder is actually attached to the piston. Make sure your clutch pedal return stop isn't adjusted so far out that it is allowing the pedal to move to far back when you let off of the clutch and pulling the rod out of the master cylinder.
