83 CJ7 350 tbi, TH350, D300 twin sticked & clocked, narrowed Chief D44 Eaton Elocker & Moser shafts, Explorer 8.8 Detroit locker, 410's, RE 4.5" spring lift 1" body lift, 35" Claws, cage tied to frame, Corbeau baja seats, HD tie rod and draglink, u-bolts flipped, custom skid plate and sliders, Warn 9.5ti winch with Amsteel synthetic line
You should NEVER have your cj in 4 wheel drive on a dry surface, bad things can happen.
cj's have gear driven transfer cases and they bind up when either the front or rear can't slip some.
Thanks. The problem arises on patchy snow covered roads and I hit a dry spot. The spot is short, then back on snow. I'll stop looking for problems in the DT. Thanks again!
