cutting shimstock
IOPort51
- Featured
- 5
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
This thread is about transmissions, shim stock, tools and bearings.
The t-18a that I suspect is a 1975 jeep. One of the points of interest is that the assembly drawings indicate that I should have a "spacer ring" between the snap ring and the case where the input bearing enters the case. Mine, is absent.
I have noticed that the input shaft has a bit more end play than I would expect which indicates the bearing retainer is not doing a sufficient job of restraining the bearing and/or the roller bearings between the input and the main shaft are incredibly worn.
The rabbit that the snap ring should be the thickness of the snap ring plus a couple thousandths, Mine is about .025 deeper than the snap ring is thick. this allows the bearing to rock.
If I cut a .02 shim to go behind the ring It will give me .05 clearance which should take a lot of play out of the shaft end. This also opens the 3-4 synchronizer up .025
The second possibility is to turn the face of the bearing retainer 025 and make the rabbit shallower. This also has an affect on 3-4 synchronizer.
And the bearings and the races at the input to main shaft point look good.
Now for the really important question, anybody have a trick and cool way of cutting shim stock into a ring whose ID is maybe a 1/4" smaller than the OD ??
I am considering .025 piano wire as well, 3 or four turns but it would be a problem keeping it in position.
I have found a web site that has a great way to cut the shim but it takes a day and a half to make the tooling. A lot of work for one shim, even if it is perfect. I don't see needing another in this life time.
