D30 ring gear torque specs
Took me awhile but here's what the jeep fsm said.
bearing caps 55 ft lbs.
ring gear bolts 40 ft. lbs min.
first time I've seen them say min.
I always use locktight on the ring gear bolts
Thanks old dog, got it together I done 55 on the ring gear and 55 on the bearing caps. Used red loctite on em. Had to put some new spider gears in my dads 79 QuadraTrac , the splines on the passenger side stripped. The new gears really tightened it up.
Sent from my DROID3 using Tapatalk 2
$70.00
  35.0%
