Dauntless 225 high rpm's at idle.
Supdaddy
Hello. Great site and always very helpful. I'm not much of a forum poster type guy but value all the info I find here.
I have done so many searches for my problem googling just about every variation of my question but can't seem to find an answer.
Okay so here we go. A few months ago I pulled a '48 CJ2a out of the deep Maui jungle. It's been a blast bringing it back. I got the Dauntless Buick 225 V6 225 v6 odd fire restarted after a few weeks of workin on it. It started up and ran sounded pretty bad because the headers were rusted out. Other then that seemed to be running well. The other day I finally got my new headers and installed them and started up the motor. Sounds Awesome!!!! Only thing is it seemed to be running at a high rpm. I put a new guage on it and sure enough idles about 1200-1500 rpm. If I turn down the idle screw it will lower the rpm's but it will eventually die. So I have to keep giving gas to keep the rpm's up to keep it going. I checked timing and it was pretty out of wack. I adjusted it to 8 btdc not much change. The only new things on the motor to get it running were the plugs and wires rotor condenser cap and new points.
Any ideas why my idle is sooooo high? I mean the engine is running like a champ. No backfire no smoke no smell. It's better then I could have hoped for. Please help if you can. Sorry for the long post. Thanks.
There are probably 100 ways to adjust and set a specific carb. Figure out which one you have (carb) and search more on it too for more things to look at.
