Diff Differential replacement
Differentials
A Dana 44 they came in 5s and scout's that are the correct width
East Coast Gear Supply can also build whatever you want. I ordered a Dana 489 and it came with disc brakes, all lines plumbed with proper fitting sizes, new e-brake cables, correct width, and proper spring perches for my CJ springs (could specify for others like those with JY spring swaps), and all needed hardware. A 99% bolt-in option.
Just for Thought......
There are not many left anymore,
BUT DJ-5 POSTAL Jeeps had a Factory Limited Slip Rear Axle.
Scout out your local junk yards.
They are a bolt in, just check the gear ratio.
