Distributor check valve vs Vacuum check valve
Techlight
California desert
1984 CJ7: 4.2l i6 (mild cam), Team Rush, Howell TBI, T5, D300, D30-front, AMC20-rear, 33/10.5/15 BFG A/T's........................
1964 Kaiser CJ5 (sold),
1960 Willy's CJ5 (sold)
Is there a difference between a distributor check valve and a vacuum check valve? I ask because I ordered a distributor check valve from carparts online and I received a vacuum check valve.
I know the originals look different and actually say "dist" or "vac" on them...the one I received is smaller than the original also.
Any thoughts/advice?
Oops, almost forgot: 1984 Jeep CJ7 AMC 258 i6 / 4.2l i6
Thanks...
Their both check valves and should work. All it does is keep the flow going in one direction.
Looking at the fsm for my '86, there is a vacumn reservoir w/check valve in the system, plus a few other check valves and reservoirs. The later CJs do have quite a complex emissions system and making sure everything is working right can be a challenge. There is a guy on the net who does explain it all, maybe somebody has a link to it. Here it is and I see a few others also:http://home.sprynet.com/~dale02/home.htm
$100.00
  50.0%
