Duantless v6
Duantless v6
dirtybird
austin tx
69 cj5 duantless v6
I have been messing with my jeep for a couple days the passenger side tailpipe smoke And is usually has exhuast that is colder then driver side tail pipe so just to see what would happen I started to pull wires off the spark plugs from the passenger side of motor (2,4,6) and low and behold regime did not skip a beat with all three wires pulled off I know it's an odd fire so I have been scouting the Internet trying to see if that side of the motor didn't work as hard as the other maybe
I don't know what to do here just feel like its not running right is my timing to advanced ? To retarded? What could cuase this to happen?
I don't know a lot but I do know that an engine should die if you pull off half the sparking wires
Right?
Right?
:)You need to do a Compression test or a Leak Down test or both on all cylinders......that will tell you the condition of each cylinder.......The motor will run on 3 but if when you took those off and there was no noticeable difference in sound or RPM it may tell you there is no compression on that side or at least they are all weak............a motor is nothing more than an Air Pump that traps air compress's it , and sets off a fuel charge........check it out!
:D:D:D:D
